Twitter/X embedding issue
(@wdepri)
[#14102]
Hi, when posting a link to a post on X/Twitter using the x.com url, the embed doesn't work. It simply changes the link, and displays as "twitter.com". If you post the same link but change "X" to "twitter" it then embeds properly.
I saw that there was a similar issue with the wpDiscuz plugin and that it had been fixed, but I am seeing this issue on wpForo and was just curious if this is the expected behavior and that folks should post the "twitter" version of the link and not the "X" version. TIA!
