"Development Enviro...
"Development Environment Detected" message
(@filmmusicnotes)
[#14735]
Hi gVectors Support,
I'm running wpForo version 3.2.2 on a staging site.
The WordPress dashboard repeatedly displays this notice:
“gVectors: Development Environment Detected. This site is running in a development environment. Some features, including gVectors-Addons updates are disabled.”
I've checked wp-config.php and there is no WP_ENVIRONMENT_TYPE constant defined. I also don't have the WP STAGING plugin installed.
Is there a supported way to explicitly mark this site as an approved development/staging environment, or permanently disable this notice without changing the site's environment to production?
Thank you!
Posted : 13/10/2026 1:19 am
Please note that this message doesn't impose any limitations on the addons, so you can continue using them without any concerns.
You can dismiss the notice, and it won't appear again for the next five days.
Posted : 14/10/2026 12:52 pm
