[Solved] add tiktok to embeds?
(@flaren)
[#6176]
everyone I know nowadays is using tiktok. Maybe possible to add an embed feature for tiktok?
Hi @flaren,
The addon is already supported the TikTok embedding. See the example here: https://addons.wpforo.com/community/postid/3230/
Just make sure the "oEmbed Functions" option is enabled for the Dashboard > Forums > Settings > addons > Embeds admin page.
(@flaren)
@astghik I have this on but when I post a link of a video from tiktok it just shows the link. Doesn't show the player.
(@flaren)
@astghik hmm it looks like my version is 1.3.5 which is outdated. Let me try updating it. For someone reason it did not show that there was a new update in my wordpress for this plugin.
@flaren,
  • Navigate to Dashboard > Updates  admin page
  • Click on the "Check Again" button
  • Then try to update the add-on again (update it from the same page)
Check update
(@flaren)
@astghik thanks! I actually haven't updated my wpforo in a very long time. I was still on 1.65. I just updated it and now I can install the new embeds.
(@flaren)
@astghik I have enabled oembed but it shows the tiktok link as a link. Why is that? Do I need to install oEmbed plugin or is this packaged together with the wpforo embed plugin?
(@flaren)
ok I solved the issue. I had to update my wordpress.
