Duplicating comments
(@samshow13)
Topic starter   [#5395]
After click on load more button - some of comments are duplicating.
http://otziv.supernelly.ru/2020/03/07/otzivi/
Tryed to remove vote data and restore all.
(@samshow13)
I thought that there is some plugin conflicts.
And decided to test on clean new site - gave you previuos link with exported comments.
@samshow13,
Please send the admin login details to info[at]gvectors.com email address. I'll ask the developers to check the issue for you.
(@samshow13)
sent it to info@gvectors.com
Thank you. We'll check and update as soon as possible.
Hi @samshow13,
In the case of the wpDiscuz 5, the ordering is being made by comment date, not by comment ID and as far as the comments are imported, so this issue takes place.
In the new version of wpDiscuz 7 This is already fixed, i.e the ordering is making by ID. Please Download wpDiscuz 7 Beta-7 and check it. The issue will be already solved.
