Filter by recent po...
Filter by recent posts
2 Reactions
(@mickdom)
Topic starter   [#4346]
can you filter out the protected posts from the count so that no empty lists are displayed in recent posts?
Alternatively, I could hide the menu item of recent posts for guests. But I can't do that in the group of guests!
Thanks in Advance!
Best regards
Zwischenablage01
Hi @mickdom
Thank you for letting us know. We're going to check the issue.
I'll update the topic asap.
Hi @mickdom,
The issue will be fixed in the next version release.
mickdom reacted
(@mickdom)
Hi Astghik,
I found another issue. The last info bar in the statistics box is not displayed because $stats['last_post_title'] is empty. Also entitled Posts?
Please help, we need that last info bar for "Unread Posts" and "Tags".
Best regards
statistic   wpf stat other
(@mickdom)
Hi Astghik,
sorry, I updated this post. I hope you see it 🙂
Best regards
@mickdom
Do you see a warning message in the error log file that the $stats['last_post_title'] is empty?
Have you customized wpForo theme files?
(@mickdom)
Hi @astghik,
no Issues found and the Error Logs is empty! I have no files customized!
I temporary commented out a line to check the last post title:wpforo/wpf-themes/classic/footer.php line 56.
Thanks in advance!
errors
(@mickdom)
Even as a registered user, it is the same. Here are the unauthorized forums listed.
current posts
(@mickdom)
Posted by: @astghik
@mickdom
 Currently the last information bar is displayed in the statistics field. I tried to replicate the issue on another webpage. I could not replicate it. I don't know how this error arises.
(@mickdom)
Now I found the issue. If I reset the cache, then are the last information bar is disappeared!
reset cache
Why is there a button twice?
buttons
(@mickdom)
Posted by: @mickdom
Ok, the first button is "reset cache" and the second (below) is "reset user-cache". Where can I change the name of the first button from "Lösche User-Cache" to "Lösche Cache" ? I can't find it in loco and your phrases site!
@mickdom
Could you please edit the language (in your case German ), click on "Sync" button, then save it. And try to find it again.
Sync
mickdom reacted
(@mickdom)
Posted by: @mickdom
Hi @astghik, are there any further information?  Thanks in advance! Best regards
@mickdom
Sorry for the late response.
Please let me know what "last information bar" do you mean?
(@mickdom)
Posted by: @mickdom
Hi Astghik,
Best regards
Hi @astghik,
I attached an Image.
Best regards
bar
(@mickdom)
Hi @astghik,
I found something! If a user writes a reply and uses only a quote himself, then an empty post title appears under "first topic and replies"! Is this the reason why the "last information bar" is not displayed in the statistics section because the reply title is empty?
Best regards
(@mickdom)
with a forum on another website I can't retrace it with the same permissions. As guest the last authorized post is displayed in the "last information bar". What can be the issue? I send you the link of the website in a private message.
