I bought the whole package of plugins. All of them work as they should, only the myCred plugin after installing and turning on shows the message: myCred plugin is not installed! and the plugin does not work.
Search
Close
AI Search
Classic Search
Dec 31, 2024 1:16 pm
Dec 31, 2024 1:31 pm
I have already pointed this out to you in the wpForo support forum
This message appears because you have not installed the myCred plugin.
What is not installed cannot be integrated
You have only installed the wpForo - myCRED integration but not the myCred plugin
Install the myCred plugin
https://wordpress.org/plugins/mycred/
Dec 31, 2024 2:09 pm
I just read it and understood. Thank you
