Default cross post forum for all new posts
(@bdebruin)
[#3271]
Hi there,
Is it possible to set a default forum for x-posting so all new posts will automatically sync. My posts come from RSS feeds and are not manually created.
Also: I also create post manually through WP User Frontend posting. Is there a custom field I can use to set forum to x-post to.
Many thanks, Bas
(@usernamemi)
Estimable Member
Hi @bdebruin,
From my experience with auto posting plugins and cross-posting on wpForo.
My auto-posting plugins are from CodeRevolution.
I had to use custom development. Because 1) wpForo is checking if there is a logged user when auto posting, and through cron there is no logged user and 2) Each rule in the auto-posting plugin has to send the id of the desired subforum you want to auto-cross-post, through Post Custom Fields.
(@bdebruin)
Hi @usernamemi
Any change you can share the custom development here?
(@usernamemi)
Estimable Member
It is very dependent of my setup - theme and those auto-posting plugins. Then, with every update of wpForo and cross-posting plugin, manual php edit is needed, to keep the functions.
Depending on your own plugins, setup and advanced knowledge, it could help or not. Let's talk more by PM.
(@bdebruin)
What is the best way for you for a PM?
