Flag icon is not displaying
(@jatin-singh)
[#6268]
I recently installed the flagging addon and I am having issues making the icon display on the comments. I Have installed the plugin and enabled it on the settings but the icon is not showing up. I have also disabled the icon. Not sure how to make the icon show up.
flag icon
font awsome
flagging enabled
Hi @jatin-singh,
Please enable back the option and leave the example URL to allow us to check it.
IMPORTANT: In case your theme uses old versions of Font-Awesome lib, you should not disable this option. The theme old version doesn't support new version icons, thus some wpDiscuz icons might be lost.
(@jatin-singh)
Hi Elvina,
Thanks for your reply. We are still having issues displaying the flag.
Right now we are hiding the comments when you are not logged in
https://decameronproject.org/stories/incident-report/
@jatin-singh,
Please send some testing user's login conditional to info[at]gvectors.com to allow us to check the issue.
