iPhone 6 plus not a...
iPhone 6 plus not able to copy and paste the comment URL link
(@pyue6299)
Topic starter   [#4131]
Hi author
I am testing out my site and come to a problem when copy and paste the comment link using the default wpdiscuz function. There is a default message pops up when i clicked the copy comment URL icon, and when i hover to some text input field in iPhone 6 plus, it does not show the option to get the link pasted.
Android, Window, Mac works just fine. Here is the post URL:
https://jdclab.com/pure-metal-jewelry/%e9%91%bd%e7%9f%b3%e4%bd%9c%e9%91%b2%e5%b5%8c%e7%94%a8%e9%80%94/
Please advise.
Regards
Patrick
(@pyue6299)
Also, when you click the copy button in iPhone, after the click, it will scroll up to the top of the page, so weird.
ok @pyue6299,
Thank you for letting us know. We'll check the issue.
(@pyue6299)
thanks for your effort.
(@pyue6299)
Hi team, its been 3 weeks. Any updates on this? Thanks!
(@pyue6299)
Hi team, any update? i really need to fix this feature. Thanks!
(@pyue6299)
Hi author
Patrick
@pyue6299
I'm sorry, but I cannot update any info here. The issue comes from the iPhone devices for sure. We'll try to find some workaround in the next version release.
(@pyue6299)
ok thanks! As a quick solution, can i add a custom button in class.WpdiscuzWalker.php for the same function?
Can you advise me the code?
Thanks!
@pyue6299
If there is some solution I'll provide for sure. But there is nothing I can share with you.
(@pyue6299)
even writing custom code for a new button can't solve the issue?
@pyue6299
I'm sorry, but we cannot find any solution yet. Trust me, if there is any solution I'll share with you for sure.
