[Solved] Upvote, Downvote, Reply Buttons Aren't Working
(@jwegmann27)
Topic starter   [#675]
I am trying to incorporate wpdiscuz comments into my site, and the buttons besides the share tiles aren't functional. I have cleared the cache, and disabled all other plugins with no avail.  There are no errors I can see by opening the console in developer tools. You can see the error at this url:
http://morty.gimmeinfo.com/teen-invents-drought-fighting-water-storage-miracle/
Also, other things are weird with the plugin currently. For example I have show sort options on and I still can't see the sort options. The div.wc-form-footer was also set to display: none by default which is strange because it contains the submit button.
(@strefa)
Hi there,
I have similar problem to yours.
After upgrading to 4.0.2 wpdisquz is breaking with JS.
Looking in the same way like on your page (buttons not working etc).
Also have some JS errors (see pic).
Any ideas?
wpdis
Please deactivate, delete wpDiscuz, then search and install it again. Then Delete all caches, purge CDN if you have, then do CTRL+F5 twice on a blog page.
(@strefa)
Done it many times. Nothing helps.
It means something incorrectly configured on your website. You can connect via FTP and check if all those JS and CSS files exists in /wp-content/plugins/wpdiscuz/assets/ folder. All are there, I have no doubt, but for some reason they can't be loaded to visitor browser from your server. This is a server or website configuration issue, there is no any chance to fix this through wpDiscuz plugin code, this kind of problems are not plugin development problems. You should check all .htaccess files, folder/file permissions (755/644), all security/cache plugin configurations, server status and local/browser caches.
(@strefa)
Before upgrading to 4.0 it was working allright.
I checked folders and theese files are not in. I have no idea why script is looking for wpdisquz.min.js insead of wpdisquz.js
There is even no such folder like /validator/ in /assets/third-party/ or /tooltipster/.
Have no idea why plugin is referencing to them.
I had suspiscious to cloudflare but development mode nothing changes. Can you tell me where can I find code for referencing to js and css files?
(@strefa)
Hi there,
after few days it started to work fine. Everything up.
Thanks.
