SyntaxError: Unexpected token h in JSON at position 0
(@jaherrera)
Topic starter   [#3373]
Hi dear.
I like very much wpdiscuz, but the only problem I arise in the instalation in my site is that each time I reply a post I get the error message "SyntaxError: Unexpected token h in JSON at position 0"
where 'h' is the first letter of the comment box
Any idea how to fix that?
thanks in advance.
Juan.
Error snapshot
Error snapshot
Hi @jaherrera,
This is a plugin conflict. Some plugin generates error in server and affects all other plugins AJAX requests. You can find it by disabling all and checking wpDiscuz.
Also please leave your website URL to allow us debug the error.
(@jaherrera)
thanks for your quickly response.
I followed your advice. I deactivate almost all the plugins but It continues running bad. It's a pity because the rest of features are fantastic
I leave the url : https/www.sigueimaginando.com
Hi @jaherrera,
Please switch to some default theme and check again. If you use some cache plugins, please keep those plugins deactivated during this testing.
(@awuja)
Hey, I'm also having a similar problem at www.leadingcomment.com
SyntaxError: Unexpected token * in JSON at position 0
at JSON.parse (<anonymous>)
at Function.n.parseJSON (jquery.js:4)
at Function.a.parseJSON (jquery-migrate.min.js:2)
at Object.<anonymous> (wpdiscuz.js:816)
at i (jquery.js:2)
at Object.fireWith [as resolveWith] (jquery.js:2)
at y (jquery.js:4)
at XMLHttpRequest.c (jquery.js:4)
Can you help?
Thanks,
A
(@awuja)
Me again,
This is a conflict with AntiSpam by CleanTalk, I think on the POST events that go through?
A
(@awuja)
Now I'm getting wpdiscuz-ajax.php net::ERR_CONNECTION_CLOSED after a few mins on the page.
Ho @awuja,
Please leave some example URL to allow us to check it.
(@awuja)
(@awuja)
I'v reduce the refresh rate from 10 seconds to 30 and that seems to have worked- I think I'll need to pay more for hosting to support the number of requests.
Thanks,
A
Hi @awuja,
Please confirm that the issue is solved?
