Supercharge doesn't began
(@raullopez_zn)
Dear all, as always I update to your last version of Discuz and when it finish and I launch the supercharge process it doesn't began, instead of a process bar I have a blank square which didn't move. I try to disabled and enabled the plugin but it happen the same and also I try to uninstall and install it but the result is the same. What can I do with it? Now I only see the new comments and I can't see the old ones before the upgrade.
Hi raullopez_zn,
Please send admin login details to support[at]gvectors.com email address, we'll fix it asap.
Ok, we've created a solution for you, please read this topic: https://wordpress.org/support/topic/if-the-supercharge-my-comments-button-does-not-work?replies=1
