2 problems with the plugin
20.1 K Views
(@scooter)
Hello, I have 2 problems with the plugin.
1. do not appear voting buttons, only the counter. Although included in the settings.
2. When you subscribe to a comment, require confirmation of subscription. For admins and guest. The settings are tick Disable subscription confirmation for registered users, Disable subscription confirmation for guests.
Hi Scooter,
Please read this support topic:
https://gvectors.com/forum/how-to-and-troubleshooting/missing-thumbs-2/#post-1540
I'm sorry but I didn't follow your second question.
(@scooter)
Thank you helped
(@scooter)
The plugin requires a subscription confirmation to comment, although the settings should not require confirmation
If you want to disable this function please check(enable) these two options:
wpDiscuz disable comment subscription confirmation
(@scooter)
Yes ticks are. But still to be confirmed
(@scooter)
and how to put noindex and nofollow for external links left by commentators in the field of Website URL field?
(@scooter)
Help me please
Hi Scooter, plugin will always requires confirmation for guest which do the first comment. After the first comment it'll not ask for confirmation. As per logged in users if those are logged in and if you've disabled registered user email confirmation they will not be asked for confirmation.
wpDiscuz automatically adds rel="nofollow" to all external URLs. If you insert some URL (not using quicktags) in comment, it's being replaced to a Link. This link includes rel="nofollow" attribute. You don't need to do an extra changes.
(@scooter)
Indeed, I looked at the source code of the links in it present nofflow. just my browser plugin does not show it
<a rel="nofollow" href="http://myaltynaj.ru" target="_blank"> Maxim </a>
how to insert a tag <noindex> into a link? to happen
<noindex><a rel="nofollow" href="http://myaltynaj.ru" target="_blank"> Maxim </a></noindex>
(@scooter)
The fact is that even if I am the site administrator write a comment on my mail comes confirmation email subscription. Although I logged into the site
Posted by: Scooter
  Indeed, I looked at the source code of the links in it present nofflow. just my browser plugin does not show it <a rel="nofollow" href="http://myaltynaj.ru" target="_blank"> Maxim </a>
I'm sorry but wpDiscuz doesn't have such an option. The rel="nofollow"  is more than enough for Search Engine Bots. So we've not added other options. User browser doesn't matter, it's only important for SE. This is SEO component.
Posted by: Scooter
Please send admin login details to support[at]gvectors.com, we'd like to test it.
(@scooter)
Posted by: Tom
Posted by: Scooter
Send your mail administrator login and password?
(@scooter)
Posted by: Tom
Posted by: Scooter
In Russia, there is a search engine Yandex. For her, it is desirable to enter into links noideks. Just do even if the link is prohibited for indexing these tags, they still transmit weight. Better yet, make a redirect to disguise links or links through java script.
Can I plug in the code itself put noindeks for links?
Could you please leave your website URL?
Ok, I see.
Please put this code in your current active theme functions.php file:
function wpdiscuz_yandex_noindex_tag($comment){
    $comment = preg_replace_callback('|<a[^><]*href=[\'\"]+([^\'\"]+)[\'\"]+[^><]*>.+?</a>|is', 'wpdiscuz_yandex_noindex', $comment);
    return $comment;
function wpdiscuz_yandex_noindex($match){
    $url = get_bloginfo('url');
    $parse = parse_url($url);
    if( strpos($match[1], $parse['host']) === FALSE ){
        $link = '<noindex>'.$match[0].'</noindex>';
    else{
        $link = $match[0];
    return $link;
add_filter( 'comment_text', 'wpdiscuz_yandex_noindex_tag' );
(@scooter)
myaltynaj.ru
(@scooter)
I insert your code, but the tag <noindex> does not appear in the source code links
This is tested code, it works fine. It seems you've added it in wrong place. Please show some screenshot where have you aadded this code. I need make sure it's correct theme's correct functions.php and it's not iinsid of other codes or conditions.
Also try to increase hook priority, change the last line of code with this:
add_filter( 'comment_text', 'wpdiscuz_yandex_noindex_tag', 3 );
And leave some screenshot of URL you're adding in comment content. Do you use simple URL or Quicktags or something else?
