[Solved] Error 404 for subscribers using private messaging
(@iain-morrison)
[#14569]
ON my new site admins are able to use PM between them but when users try to use the same function they get a 404 page not found when they click a members name to be able to message them. Can you tell me what setting is preventing them from see the other members profile to make a private message?
I should add that I am unable to find any settings for Private Messaging in the WPForo settings at all. It doesn't event come up when I do a search using the search bar.
(@iain-morrison)
I have also found that when they try to view their My Profile page they get the message which says "You do not have permission to view this page".
Can you also tell me where this permission is set? Setting this this may cure the problem.
(@iain-morrison)
I have resolved this, Was a mismatch between WordPress subscriber capabilities and WPForo Registered capaibilities
