[Solved] Cross posting of old posts and forum replies
 Vl@d
(@vld)
Hello!
Does this addon work with old posts and forum replies? Could i applay topics for each posts after migration? Or it'll be new topics for posts?
Hi @vld,
First of all, thank you for your interest in wpForo Blog Cross Posting addon.
I'm sorry, but I don't follow you well. Please try to explain in other words.
Currently, you can crosspost the existing Blog Post to Forum Topic.  And the wpForo plugin has built-in tools to move, merge and split topics:
Open the tool and use the Split Topic tab:
 So the forum replies can be moved to any target forum.
 Vl@d
(@vld)
Thank you! You understood right.
It's no good that forum replies not shown below blog post (in comments area). It isn't comfortable
@vld,
This add-on has the following feature:
Blog Post Comments to Topic Replies crossposting and vice versa
  • Add
  • Edit/Update
  • Delete
You just cannot turn Forum Topic to Blog Post for security reason as the only authors, admins (high-level users) have permission to crate posts.
 Vl@d
(@vld)
I mean forum replies turn to blogpost comments
Hi @vld,
If this blog is already turned to the forum it is possible, otherwise not.  The forum replies will be cross-posted if you enable the Forum Reply to Blog Comment synchronization option.
 Vl@d
(@vld)
Thank you! Everything works!
