Check it out here: https://nerdswire.de/musik-hiphop-fans-akribie-aphroe/
wpDiscuz GIPHY Integration
5
Posts
2
Users
1
Reactions
1,946
Views
Aug 20, 2021 9:38 pm
Aug 21, 2021 9:14 am
Hi Tobias,
Please delete all caches. If the issue is not fixed, disable all plugins and check it. This is a plugin conflict. The GIF addon works fine on hundreds of website, this is not a general issue for sure.
Aug 21, 2021 4:33 pm
Hi @tobias-kromberg,
if the disabling of other plugin doesn't help, please send admin login details to support[at]gvectors.com email address. We'll login and fix this issue.
Aug 24, 2021 11:02 pm
^^ works. was cache.
Greetings from Germany.
Aug 29, 2021 9:18 pm
BTW: You don´t use it here on this forum?
