[Solved] No icons visible
(@senderos44)
[#4337]
Hi
Is there a way I can get round the persisting issue with WPDiscuz icons not being visible on my page? See example:
http://www.okiemmiszy.pl/2017/09/odszkodowanie-za-opozniony-lot/
Please note the whole widget appears to be broken - no 'Like'/'Dislike' comment icons visible neither.
Thanks for your support
Hi @senderos44,
Please navigate to Dashboard > Comments > Settings > Styling admin page, make sure the "Do not load Font Awesome css lib" option is disabled.
(@senderos44)
It worked! Thank you a lot - the tread can be closed.
