[Solved] Advanced Likers
(@fixit)
[#14554]
RadarDetect
RMI Vote Dashboard
Recent Votes
VOTE DASHBOARD
Top Comments
Hi everyone,
We’ve been experimenting with turning wpDiscuz comment voting into something more meaningful than just static like/dislike numbers, and ended up building a custom system that adds real-time “status” badges to comments based on engagement.
The idea was simple:
If votes exist, they should say something.
So instead of just showing counts, comments now get labels like:
  • 🔥 TRENDING
  • 🧨 EXPLODING
  • 🚨 CONTROVERSIAL
  • 💀 RATIO’D
  • 🗂️ ARCHIVED HOT
These are calculated from:
  • total votes
  • like vs dislike ratio
  • recency of votes
And then injected into the frontend dynamically.
What it does:
  • Logs every wpDiscuz vote into a custom database table
  • Imports existing vote totals from comment meta (wpdiscuz_votes_seperate)
  • Calculates engagement states per comment
  • Adds visual badges above comments in real-time
  • Highlights “hot” comments visually
  • Optionally pins the hottest comment at the top
  • Sends alerts when a comment gets heavily downvoted
Anyway, check it out: https://ratemyinsta.com/
Regards,
FixIt (RMI Web technician)
