wpDiscuz - Integration with Ultimate Member
38.8 K Views
(@isiostat)
Topic starter   [#3292]
I recently installed wpDiscuz and I'm trying to integrate it with Ultimate Member but I'm not familiar with adding code to the Functions.php file in themes.
I haven't been able to find any relatively updated resources on doing so for newcomers. If you can help me out, it'd be much appreciated.
Cheers, Isiostat
Hi @isiostat,
Please follow these steps:
  1. Navigate to Dashboard > Appearance > Editor admin page
  2. Select the current active theme from the "
  3. Chose the functions.php file,
  4. Add previously copied  integration code form Dashboard > Comments > Settings > Integrations admin page
active theme
Isiostat reacted
(@isiostat)
Thanks for the reply. I added the code, but after enabling the comments section it shows the following:
wpDiscuz Login
Posted by: Isiostat
wpDiscuz Login
It says that this is Akismet Plugin message. You should find an option in Akismet plugin settings to disable it or just contact the Akismet plugin support team.
