Syntax Error: Unexpected token
(@przemm)
Team,
I have just found your plugin and it looks really great. The only problem I have is that I am not able to post comments as a guest as I'm getting the below error message:
Syntax Error: Unexpected token <
Can you please help?
(@gagik)
Active Member Admin
Hi przemm !
Could you please be kind and provide your current website URL in order to see the issue?
(@przemm)
Hi John,
Sure - www.bookiescanlose.com
I have just enabled your plugin. Please try to add any comment under any post.
(@adi66)
i have similar problem when i reply to any comment it gives SyntaxError: Unexpected token p.
Can you please help me on this
Thanks 🙂
(@przemm)
Hi, any chance that someone will look into this issue? Great plugin and so poor support...
