Simple Text box
(@della)
Topic starter   [#1242]
Hi Tom,
I have increased the font size on the form plus we have a longer than usual form.
Consequently if someone misses a required question and attempts to submit they may miss seeing the talk bubble showing that they missed a question.
My thought was to put a stagnate message at the bottom of the form something like:
"If the post seems to not have responded please see if you missed a required question above."
1. Can I add a text box after the questions before the submit button ?  I'd like to say something like:  "If the comment submit buttons seems to not have responded please see if you missed a required question above."
2. Is it possible to show a message when this occurs by the submit message similar to the "required field" bubble - that says something like "Please complete all required fields above."
As a short term work around I added a question but is a bit awkward and odd.
I look forward to your creative thoughts.
I'm sorry but this requires lots of changes. It can't be added in near future releases. I'd recommend to use two column layout on for your form. it'll look more compact:
screenshot 2
Della reacted
(@della)
Tom,
I understand the challenge.  The idea of 2 columns is a great one. I will go play with that.  Thank you.
