Problems after comment
(@Eonegin)
Hello. Thank you for great plugin.
I have a small problem: when I post new comment I see ajax "Loading" icon and nothing. After reload page I see my comment. How I can fix this problem? Thank you!
Hi EOnegin,
Please leave some example page URL.
(@Eonegin)
(@ecoengineer)
similar problem here. After commenting, the page loads again and returns an error page which is the post url with /false (eg.  http://www.ecoengineer.gr/2015/03/%CE%BE%CE%B5%CE%BA%CE%B9%CE%BD%CE%AC%CE%B5%CE%B9-%CF%84%CE%BF%CE%BD-%CE%BC%CE%AC%CE%B9%CE%BF-%CF%84%CE%BF-%CE%BD%CE%AD%CE%BF-%CF%80%CF%81%CF%8C%CE%B3%CF%81%CE%B1%CE%BC%CE%BC%CE%B1-net-metering-2/false)
If you refresh the page it returns to the post with comments.
Kind regards,
Nikos
(@ecoengineer)
weird..it seems like working now
(@ecoengineer)
No actually, it doesn't work. It is a bit complicated. It happens only for the first comment. The rest of the comments work good. Any ideas?
Hi Ecoengineer,
Please go to Dashboard > wpDiscuz > General Settings Tab, and find the "Redirect first commenter to" option.
Then set it "Do not redirect" and save settings. If it's already set this value you should save it as well.
2015-04-06_1831
Hi Ecoengineer,
Please update to wpDiscuz 2.1.10 version, we just fixed some issues regarding to the first commenter redirection.
(@ecoengineer)
thank you for quick fix. It works after the update.
