No compatibly with theme???
(@gustin)
hello, I have a problem with this plugin.
The problem is with a particular theme. The theme is directory of Ait
demo theme: preview.ait-themes.com/theme/directory2/
When active the theme, get a code in the header.
I talked to the creator of the theme and told me that is a problem compatibly with wpdiscuz.
I looked at the code, but I have enough knowledge to fix it.
It has a solution?
error
error
Hi Gustin,
could you please send this theme to support[at]gvectors.com email address? if you made any changes on this theme please send the changed one.
(@gustin)
I sent an email. check.
Thanks you.
to adapt wpDiscuz with this theme you should make this small change in wpDiscuz /wp-content/plugins/wpdiscuz/templates/comment/comment-form.php file. Please open this file and find this line:
if ($ob_stat || $ob_stat === '' || $ob_stat == '0') {
then change it to this and save:
if (false) {
(@gustin)
Perfect. good team. thanks you. thanks you. thanks you. thanks you. thanks you. thanks you. thanks you.
(@gustin)
I have bought many of your plugins added.
But I have a problem with one of them.
with wpDiscuz Media Uploader.
I have another plugns installed, and when I put wpdiscuz media uploader, the plugins can not press and write. this plugins is: Directions. he show in items.
Thank you.
ait get directions 2.3
not is a jpg file, is a zip file.
Thanks you.
Hi Gustin,
thank you for your purchase. We're here to help you. Please leave some screenshot or URL to allow us see the problem. Also it would be better if you send admin login details to support[at]gvectors.com email address. We'll check it and find the conflict point.
(@gustin)
i send you a email.
Thanks you
(@stephenking)
Posted by: Gustin
i send you a email.
Thanks you
I have been using it with MyThemeShop Theme and it works pretty awesomely. However, I didn't test it with the Genesis Framework Aspire Pro theme which I'm currently using on my blog.
