How can I move the check box from below to ABOVE the SEND button?
 Arka
(@Arka)
Hi there,
I am using your plugin with postmatic.
Would it be possible to move the "follow the conversation via email" box to ABOVE the "send" button? The way it is now it is too easy to miss it. It would be good to make it more visible as well...
Also, I seem to be unable to translate the phrase "". Where can I find it? i don't think it belongs to Postmatic because if I remove your plugin and use Postmatic straight from the box the translation appears
Thanks a lot 🙂
(@Arka1)
Forgot to add a link to my site:
http://www.autosvezzamento.it/postmatic/
Although it is in Italian, I am sure it won't be a problem 🙂
Hi Arka,
There is not an option for that, you should do that changes manually in comment-form/form.php and comment-form/tpl-comment.php files. As for the translation, it's wpDiscuz issue, we'll fix it in next 2.2.0 version. It'll available in a few days.
(@Arka1)
I thought I posted a comment... I have clicked on "notify me of follow up answers, but it hasn't appeared...
Anyway, I was asking whether you would consider making that modification in one of your future releases as I feel the mod you suggest is WAY above my non existing skills as a coder 🙂
I think it is quite important to get the layout of the box right because the way it is laid out now you first click "send" and only later do you realize that there is an option to subscribe, but by now it is too late and you have to leave another comment if you wish to subscribe to the comments.
Thank you Arka,
Sure, this is a very good point and we'll definitely do this change in next releases. You're correct, all options and fields should be filled before clicking on submit button.
(@Arka1)
Thanks. I am really looking forward to that.
I wonder how many of the people who commented in the last day or so actually subscribed (assuming they all wanted to 😀 )
