Search
Close
AI Search
Classic Search
 Search Phrase:
 Search Type:
Advanced search options
 Search in Forums:
 Search in date period:
 Sort Search Results by:
Comment Form is Missing!
(@austin)
  [#4310]
To whom it may concern,
I'm having an issue where the comment form is not showing at all, and even my default comment form isn't showing up on my theme.
I've done the 5 steps on another thread listed by Tom here
https://gvectors.com/forum/how-to-and-troubleshooting/resolved-wpdiscuz-comment-form-is-missing/#post-349
and none of that solved the issue.
What other options are there for getting comments to work?
Also, if it helps, here is a sample page that I want the comments to show up on, and I use Elementor and I read earlier that there might be some problems with that as well.
Best,
-Austin
Hi Austin,
Posted by: @austin
It seems your active theme doesn’t use <?php comments_template() ?> WordPress template function, thus wpDiscuz can’t be loaded. To make sure please switch to some default theme and check again. If it works you should contact to your active theme developers and ask them to add this function in template files. More information here: https://codex.wordpress.org/Function_Reference/comments_template
