CloudFront and wpDiscuz
(@sasha)
We use wpdiscuz comment system and we want to use AWS cloudfornt on our site. But when turn CloufFront on  we are getting a lot of errors as
"Access to XMLHttpRequest at 'js' from origin 'host' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource.
As a solution we tried to dis-register wpdiscuz.js (and other plugin js files) and put it directory to footer, or display via php object buffer. Also we tried different config with native.ajax/wp-discuz ajax. So how can we use wpdiscuz
WPDiscuzComment
with cloudfront without conflicts?
Thanh you!
Topic Tags
Hi @sasha,
Please navigate to Dashboard > Comments > Settings > General admin page, enable the "Use WordPress native AJAX functions" option, delete all caches and check again.
Don't forget to press CTRL+F5 on the frontend before checking.
If it doesn't help please try to exclude the wpDiscuz plugin from the AWS CloudFront.
(@sasha)
Can you please suggest how to  exclude the wpDiscuz plugin from the AWS CloudFront?
Thank you!
@sasha,
You should exclude:
/wp-content/plugins/wpdiscuz/assets/wpdiscuz.js
I'm sorry, but I'm not familiar with this plugin. To know on how to exclude js files from AWS CloudFront,you can make search on google.
