Can't connect with Facebook
12.7 K Views
(@yifat)
Topic starter   [#3529]
I followed your instructions to allow people to comment with FB and for some reason after they click the Accept button, it keeps spinning:
Thanks for your help!
(I emailed you 7 days ago. I hope to get a faster reply here.)
Topic Tags
Hi @yifat,
This issue doesn't have any relation to wpDiscuz.
Your website is still on HTTP protocol, please get some SSL certificate and make your site secure with https protocol.
https://www.websecurity.symantec.com/security-topics/what-is-ssl-tls-https
Facebook doesn't allow use its API on the non-https website.
https://developers.facebook.com/blog/post/2018/06/08/enforce-https-facebook-login/
FB login
(@yifat)
Thank you.
That makes sense.
(@yifat)
The site is now secure and the FB button spins and doesn't connect:
http://tv.drmaggieyu.com/live
Hi
hope you've read the article I've provided in the previous post.
Facebook login require HTTPS, but your website still uses HTTP.
(@yifat)
Astghik,
I did read that article and we did make the site secure -  https://tv.drmaggieyu.com/the-importance-of-the-missing-community-in-healthcare/
For some reason, the server kicks people to the insecure part. So we're looking into that.
Thank you for your help.
(@yifat)
My site is secure and the Login with FB is just spinning -  https://imthatgeek.com/how-to-turn-your-brand-into-a-movement/
As you can see, the app is live on FB Dev -  https://www.screencast.com/t/Bg2VSuON2Z9u
Thanks for your help.
@yifat.
I see the following response from Facebook API (see screenshot below):
<div><span>URL blocked: This redirect failed because the redirect URI is not white-listed in the app's client OAuth settings. Make sure that the client and web OAuth logins are on and add all your app domains as valid OAuth redirect URIs.</span><script>if (typeof console !=="undefined" && console.log) console.log("URL blocked: This redirect failed because the redirect URI is not white-listed in the app's client OAuth settings. Make sure that the client and web OAuth logins are on and add all your app domains as valid OAuth redirect URIs.");</script></div>
This article should help you to solve the issue:
https://help.sharetribe.com/sharetribe-go-managing-your-go-marketplace/third-party-sign-up-services/how-to-solve-the-url-blocked-this-redirect-failed-because-facebook-login-error
Facebook login issue
(@yifat)
I copied the link from the instruction page -  https://www.screencast.com/t/l2e95k7NmwE
Entered it here -  https://www.screencast.com/t/yHoQjnPRt
and it's still spinning.
Hi @yifat,
We've just checked and everything works fine. Please press CTRL+F5 (twice) on the frontend before checking.
(@yifat)
Please see the link here -
It's not working on my end.
Hi @yifat,
Thank you for the video. It helps me to understand what the problem is.
First of all, please never use incognito mode with Facebook login or other login buttons. FB login button doesn't work on incognito mode, it cannot add cookies and start the session.
When you try to login via FB on firefox browser, it'll open a new dialog section with a message "Firefox prevented this site from opening a pop-up window". You'll need to click on the Options button and choose Allow pop-ups for this site option. See screenshot:
Firefox
The same is with the Chrome browser. More info here:
https://support.google.com/chrome/answer/95472?co=GENIE.Platform%3DDesktop&hl=en-GB
(@yifat)
You're looking at the wrong site 🙂
This works on - tv.drmaggieyu.com
For some reason  It is NOT working on www.imthatgeek.com/live
Hi @yifat,
I think there was missing www in the Valid OAuth redirect URIs field.
(@yifat)
Nope.
The URL in WpDiscuz setting doesn't have www.
I added and tested it anyway and it didn't make a difference. Still, can't log in.
Also. when I add the www to the domain, it drops it and goes to https:// without it.
Do you want to log in and take a look yourself?
(@yifat)
Me again...
Happy to give you access to check it out.
Dear @yifat,
Please navigate to Dashboard > Comments > Settings > Social Login & Share admin page make sure the "Use Facebook OAuth2" option is enabled. Delete all caches and check again (not on Incognito mod).
Use Facebook OAuth2
(@yifat)
Thank you. That worked.
New issue though - after the login it sends me to the welcome page for my community rather than return me to the original page.
I'm using S2Member Pro, if that helps.
Hi @yifat,
yes, this is a known issue. We're going to fix it in the upcoming version. Please wait for the next update.
(@yifat)
Gotcha.
So diactivate social login until then.
When is the next release due?
