Avatar being stretched vertically for replies only
(@wendy)
Has anyone come across this or know how to solve it?
Since updating to the latest version (5.0.5) the avatars in comment replies are being stretched vertically. Seems to only effect replies and nothing else, see attached
avatar issue
Not sure how to fix this or whether is just a bug with this version of wpdiscuz?
The avatar in the screen-grab is being pulled in from Facebook (social login), not that it should make any difference as everything was working fine with the older version.
Is there is custom CSS code someone could suggest that would make the reply av's behave properly?
Hi Wendy,
Could you please leave an example URL, to allow us check it?
(@wendy)
Hi Astghik, please check your PM's, thanks
