what addon i have to buy in order to give my users register possibilities?
I mean to be remember by plugin and my site and use the same nickname in the future?
Best,
Jacek
Hi Jacek,
wpDiscuz doesn't have registration functionality, you need to use some additional registration plugin or enable wpDiscuz social login.
More info here: https://wpdiscuz.com/docs/wpdiscuz-documentation/settings/social-login-and-share/
wpDiscuz allows adding “Cookies Consent” checkbox on the comment form. This checkbox allows users to turn ON/OFF cookies on the comment. In this case, the user will be able to leave a comment even if he/she doesn’t consent cookies.
Please read this doc for Cookies Consent:
https://wpdiscuz.com/docs/wpdiscuz-documentation/gdpr/cookies/#checkbox
Hi Astghik.
I want to get effect like that:
1. Have possibility to login with wordpress gravatar.
2. For quest have Identicon icon genereted by wordpress.
Can you assist with these?
Best,
Jacek
So to sum up:
i want to give users possibility to login to wordpress gravatar via form on wpDiscuz.
Hmm ok, thank you.
But this is possible.
Please go to https://dopracowani.pl/2018/11/05/przepis-na-sukces/
and see that there is wpDiscuz plugin.
And also see that there is gravatar or photo attached to guest user.
How this can be done?
Best,
Jacek
This is not the wpDiscuz commenting system. The wpDiscuz comments form should be above the comments and it must have #wpcomm id on its wrapper class.
Please navigate to Dashboard > Settings > Discussion admin page, try to change the "Default Avatar" option's value.
Also, I suggest you check out some avatar upload plugins such as WP User Avatar.
wpDiscuz supports WP First Letter plugin as well.
Ok thank you.
understand,
what about automatically gravatar loading for users?
For example i created account on gravatar.com.
I am a quest on my site but not logged in gravatar.com.
It is possible to let wpDiscuz know that i have gravatar on gravatar site?
Best,
Jacek
wpDiscuz just use WordPress avatar functions, it doesn't do extra actions. And yes if the user fills his/her email address in the comment form, the avatar automatically gets from Gravatar if the account exists.
Check it here:
thank you Astghik,
so only by providing email gravatar is loaging automatically? Without login?
Best,
Jacek
yes, Jacek, you're right.
