2.1.10 problem
(@wptrinfo)
Hi. we use godady managed wordpress hosting. I updated plugin to 2.1.10. But plugin dosen't work. Problem picture is here.
http://prntscr.com/6qmdeo
URL :  http://www.windowsphoneturkiye.info/
Hi wptrinfo,
We could not check this issue, because you have closed guest comments. We registered on your website but it didn't send registration email with password. GoDady is the worst hosting service around the world, if you use shared hosting plane all important and very neccesssary functions are disabled, you should pay more to get those. For example all emails are being send in 30-60 minutes not immediately, and so on...
Please send some user login details to support[at]gvectors.com to allow us check this issue.
Thank you for the access data,
We just found out that this is no wpdiscuz problem. You have a plugin called "Captcha" this plugin always causes conflicts with wpDiscuz.
Please deactivate and remove this plugin and try to use other alternatives.
