Fatal error when i try to istal ACP PRO
(@thibaut)
When i try to instal ACP PRO, i have this message: Fatal error: Cannot redeclare class ACPFrontendStyle in /var/www/vhosts/clerlande.com/httpdocs/wp-content/plugins/advanced-content-pagination-pro/acp-css.php on line 6 …
I don't have any free version active from ACP.
What can i do ?
Hi @thibaut,
As far as I see you have another ACPFrontendStyle class in your files. This may be this reason for this error.
If you have some coding knowledge you need to find one of the classes ACPFrontendStyle and rename it. If not we'll need access to change this class name on your website.
(@thibaut)
I found this plugin that seems cause the problem: Advanced Random Posts Widget
When i desactivate it, the activation of ACP PRO , seems to be OK. I return back later if i have other bad issues.
Thanks for your answer.
