"MyCred plugin is not installed!"
(@relatablerobin)
[#3029]
First run using wordpress, so stay with me.
I upload the plugin, and activate it, and I put in my token. It still says " MyCred plugin is not installed". I use my FTP to re-upload it, still the same message.
MyCred 1.0.5
Hi @relatablerobin
You've  purchased and installed the wpForo myCRED Integration addon. You should also install the MyCRED plugin for integration. Please read addons description. You can download MyCRED plugin on wordpress.org plugin directory: https://wordpress.org/plugins/mycred/
(@relatablerobin)
Solved! Thank You!
