Short Codes / Content Visibility in Cross Posts
(@studio500)
[#1487]
Hello Team
Are all shortcodes or external app content that is generated inside an original blog post blocked from being displayed within the actual Cross Post forum post, generated by the plugin?
For example, I use a plugin to display Tables within my posts (Tablepress plugin), however when my blogpost containing a table created by Tablepress is cross posted, no table content is visible.
If shortcodes or other content output from plugins is blocked, is there any way that some can be whitelisted ?
Please note, wpForo posts are not WordPress post types so you should not expect shortcode working on forum. wpForo topic and posts are different content in different tables, this is not a blog post for shortcodes. in any case you can enable it using this instruction:
https://wpforo.com/community/general-discussions/question-about-an-other-plugin-compatibility/paged/2/#post-8446
If you use Simplified (#2) or Q&A (#3) layouts you should use according layout post.php file.
