[Solved] Revoking attachment permissions to 'Read only' access breaks post layout for non-logged in users + solution
 fawp
(@fawp)
Trusted Member
[#11127]
Hi guys
First off, I don't know if this has been fixed for Advanced Attachments for wpForo 2.x as I have yet to purchase that product.
This is related to the following thread which is now closed
https://gvectors.com/forum/wpforo-advanced-attachments/2-questions-3/
Issue
For non-logged in users, if I uncheck the "Can view attached files" checkbox in the Read only access, any non-logged in user will see a broken post layout.
The culprit appears to be this piece of code
version: 2.0.8
File: wpforo-advanced-attachments/includes/class.wpForoAttachmentsTools.php
Line: 222
Code:
$attach_html .= '<br/><div class="wpfa-item wpfa-file"><a class="attach_cant_view" style="cursor:pointer;"><span style="color:#666;">' . wpforo_phrase('Attachment', FALSE) . ':</span> ' . urldecode( basename($filename) ) . '</a></div>';
Solution
By adding a space between color: and #666 the issue disappears.
Kyle
 Kyle
(@kylew)
Prominent Member
Hi @fawp,
Advanced Attachments doesn't have that issue, Non-Logged-in users with Read only access(Can view attached files- disabled) see the attachments the same as in the below Screenshot
wpforo disabe attached file view
 fawp
(@fawp)
Trusted Member
@kylew Thanks Kyle,
Well, this is the HTML markup being generated
wpf ad at
As you can see, the markup somehow is broken. But, by making that small change, the markup is no longer broken.
I am not necessarily suggesting it is a problem that affects everybody, but it seems to be affecting some users (e.g. me and the other guy who posted the original topic above)
 fawp
(@fawp)
Trusted Member
@kylew I have just noticed that the Topic Starter in the original topic
mentioned the same version for Advanced Attachment as me, which is version: 2.0.8.
He also says when he updated the plugin with a newer version the problem disappeared.
Is it possible this situation was captured and resolved in a newer version?
Kyle
 Kyle
(@kylew)
Prominent Member
@fawp,
Yes, after 2.0.8 has been released 2.1.1 with CSS fixes.
Changelog 2.1.1
  • Improvement: Performance improvement
  • Fixed bug: 404 error “File is not found” when “Secure URLs” is enabled and the file name contains non-Latin chars
  • Fixed bug: Proper clearing attachment shortcodes in unnecessary places (widgets, activity stream, etc…)
  • Fixed bug: CSS Issues
  • Fixed bug: Incorrect displaying of “Allowed max size”next to the attachment button
 fawp
(@fawp)
Trusted Member
Update: the solution above needs to be applied to line 174 as well as line 222
 fawp
(@fawp)
Trusted Member
I just checked in my archives - I had not realized that I had also wpforo-advanced-attachments-2.1.1 and this issue appears to have been fixed in that version: the problem above has been corrected in there and the space is correctly inserted between color: and #666
