[Solved] Keep origina image sizes
(@venkat-mangudi)
[#7639]
Can you tell me where this option is and how to add that hook?
With my limited knowledge, I changed the file
wpforo-advanced-attachments/wpf-third-party/file-uploader/UploadHandler.php
and modified the following line
 $image_quality = isset($options['jpeg_quality']) ?
                    $options['jpeg_quality'] : 100; //Removed compression -
But that did not upload the full size image, it still reduced a 2.38MB file to 208kb or so.
@venkat-mangudi,
Please don't do any changes in the code directly and revert all your changes.
When you upload an image it's cooped and the thumbnail of that image is displayed on the post to avoid loading of large images. So please explain what exactly you're looking for?
(@venkat-mangudi)
Use case: I need to allow the users to upload images in the forums. However, the images are being compressed and the quality as seen online is sub-par. How can I turn off the compression feature in the add-on?
@venkat-mangudi,
put this code in the functions.php file of your current active theme:
add_filter('wpforoattach_uploader_class_options', function($options){
   $options['image_versions']['']['jpeg_quality'] = 100;
   $options['image_versions']['']['max_height'] = 1920;
   $options['image_versions']['thumbnail']['jpeg_quality'] = 100;
   return $options;
(@venkat-mangudi)
Thank you, Tom. I am on a wordpress.com hosted site. Not super-technical on PHP though. Can you point to me where I can edit this file?
You assistance is much appreciated.
(@venkat-mangudi)
Thank you, Tom. That worked well.
