User & Comment Mentioning with Comment Author Info
(@om-swami-meditations)
[#6939]
Dear Support - Please refer to this demo page https://addons.wpdiscuz.com/wpdiscuz-user-comment-mentioning/ which illustrates the problem that I am having. Mark's name as shown below is a hyperlink because he is an author.
Capture
Mark's Name now has two features a) On Mouseover, it shows a short bio of mark (Posts: 11, Comments: 6) and b) when I click on Mark's name, it goes to Mark's page. I think the short bio is coming from Comment Author Info plugin.
This behavior is not mobile friendly as there is no mouseover event in Mobile so you see a spinning wheel & then the author's page comes. I wanted to change this behavior so that a) There is no mouseover popup b) when I click on Mark's name, I want to show "Comment Author Info" popup which is a pretty good popup with various details including a link to Mark's page (if I want to go there).
I looked into the settings but I am not able to find how to achieve that behavior. Can you advise?
Regards
Posted by: @om-swami-meditations
Hi @om-swami-meditations,
This is not the Author Info pop-up. This is the User Mentioning addon pop-up. There is another pop-up in the User Mentioning addon. When you mention a comment with #comment-id, it'll pop-up the comment, so you don't have to go to that comment to read it.
All pop-ups of this addon are designed on mouseover event. It's not correct to make them work on "click" event and there is no way to do it. We don't want to disable the author link and ability to go to the author page.  We'll fix the mobile issue for the author-links by using another way. Please wait for this plugin update, we'll release it after the New year holidays as it's mentioned on the top of this support forum.
Hi @tomson, Thank you for clarificatons & quick response. I didn't realize that User Mentioning addon has it's own popup.
Look forward for the mouseover fix.
Hi @tomson, Wishing everyone at gvectors a healthy and happy 2021. Is there any update to this?
Hi @tomson, just a gentle follow up to this request. Kindly let me know if there is an update on mouseover fix. or a timeline for the same.
