Downloaded & activated add on, but can't find moderation settings
(@richards1052)
[#9701]
I've downloaded and activated the add on.  I've checked in the post comment page and in the comment pg in the admin interface and none of the moderation/editing options have changed fr the WP default.  Am I missing something?
Also, would you consider a feature allowing the admin to restrict specific commenters to a specific comment limit per post?
Posted by: @richards1052
Could you please explain using some screenshots?
We're really sorry, but we may only suggest you check out the "wpDiscuz Limit Comments per User" feature.
(@richards1052)
I mow see the moderation Options in the drop down menu with the settings icon On the front end. But these settings would be most useful in the comment page backend where I moderate and deal with all comments for all posts in a single place. Is it possible to hv them in the backend ?
@richards1052,
As the description of the addon says it's designed as a toolkit to manage comments on frontend. It doesn't have an option for the dashboard.
This is not what I need. I don't need a global limit on numbers of comments for all users uniformly. I need a comment limit option for specific commenters.  You should consider this as an add on.  I'd buy it.
Currently, we have plugin customization and custom addon development services at the gVectors Team. They can assess the work and create it for you. Just contact us via sales[at]gvectors.com email address and send a list of requirements you'd like to have.
(@richards1052)
@astgh I will inquire. But I am a small non-commercial blog.  I fear the fees will be geared to major commercial sites, which I will not be able to afford.
(@richards1052)
