[Solved] Comment search issue
(@joseph-hornof)
[#5507]
Hi -
I just purchased and installed this add-on and am having the exact same problem. Our settings are set to search only Content. The first search works nicely, but subsequent searches do not display correctly. We are not using any caching. Sorry, but I can't give you access to the site or the URL - this is members-only information.
Could you outline the steps needed to fix this or provide the updated files?
Thanks,
-Joe
Hi @joseph-hornof,
Please send the admin login details to info[at]gvectors.com email address. I'll ask the developers to fix the issue on your website.
Hi @joseph-hornof,
You should replace the wcsDBManager.php file. The file is attached to the post content. Just download the zip folder below:
The file is located in the wp-content/plugins/wpdiscuz-comment-search/includes/ folder.
Please don’t forget to delete all caches and press Ctrl+F5 (twice) on the frontend before checking to reload the updated CSS file.
(@joseph-hornof)
Thanks very much.  Replacing that file did the trick.  Sorry to be a little slow to reply, I had to wait for my clients to check and report back.
