Cpmpatability issue with reviews plugin
(@paulka777)
Topic starter   [#2887]
Hi Folks.
I was using the woodiscuz plugin without hiccup, but we decided to change our review plugin. It seems though that now when you add a comment in either the review system or the discuz tab they appear on both.
I suspect this is because they both use the comment type comment. Could this be fixed somehow?
I want to use woodiscuz for comments and questions, and use reviews for reviews.
(@paulka777)
Here's a screenshot, still facing the same issue.
2018 10 18 11 14 32 Blue Cameron’s Casual Sheep Costume Pullover – DogOnline
Hi @paulka777,
Could you please let us know the review plugin you're using?
(@paulka777)
Thanks for your reply:
https://wordpress.org/plugins/woo-photo-reviews/
However I had the same trouble with another review plugin too.
(@paulka777)
I wouldn't mind so much if the review did appear there, however the actual comments do not display at all:
2018 10 20 12 16 21 Comments ‹ DogOnline — WordPress
There should be 2 questions/comments and one review.
Hi @paulka777,
The review plugin you're using does not meet the standards of Wordpress. I'm really sorry, but this cannot be solved by WooDiscuz side.
