Widget disappeared on Genesis theme
(@auntie-cee)
My genesis theme has a widget at the bottom of the post where I kept some things, once I installed the comment plugin the widget is gone. I really like the new comment system, and wish to expand, but I need the stuff in the widget more.
Any chance you would know how to fix this? Thanks in advance for the help.
Hi Auntie,
Please leave some screenshot of "has a widget at the bottom of the post" item then enable wpDiscuz and leave website URL to allow us check it.
(@auntie-cee)
Thanks, after much digging, and disabling the comment plugin to make sure it was the problem,  I tried re-registering the widget and I got it fixed. I don't know why it completely erased the widget. I'll let you know if it breaks again. 🙂
