Putting a text to the end of each comment
(@mert2312)
Topic starter   [#5750]
Hi. I'm looking for a action hook which helps me to put the length of comment in a text, for each comment posted. I also need to get access to the user id of the comment author. For example, after each comment posted, I want to put a text saying: The user id of the comment author is : x and the length of the comment is : y.
Any help would be appreciated.
Hi @mert2312,
You should use the following hook to display the comment author name and the comment length message:
add_filter("comment_text", function ($content, $comment) {
$content .= "comment author is : " . $comment->user_id . " and the length of the comment is : " . strlen($comment->comment_content) . ".";
return $content;
}, 50, 2);
The hook should be added in the current active theme functions.php file.
(@mert2312)
@elvina Real thanks for such a comprehensive and quick reply. There is only one more question: is that going to change the comment content on the database, or just what is shown on the screen? Thank you so much!
Posted by: @mert2312
no, the comment content doesn't change in the database. It only displays the comment author name and the comment length message in the frontend.
mert2312 reacted
(@mert2312)
@elvina hello again, I was able to implement the code easily, thank your for that. But I had a problem afterwards: the button for "load more comments" is no longer working, it gets stuck. I think it uses AJAX but a problem occurs when I activate this code. How can I make both of them work?
@mert2312,
Please leave the example URL to allow us to check it.
(@mert2312)
@elvina It's on multiple pages, but here's one of them: https://www.glonera.com/urun/diadermine-hydralist-nemlendirici-bakim-kremi-ipeksi-doku-50-ml/
Thank you.
(@mert2312)
@elvina hello again. I had to remove the code since it interferes on the comments section on the admin panel and causing some fatal errors afterwards. how can I make sure that the code is only shown on wpdiscuz comments section? Is there a hook specifically for this purpose?
@mert2312,
Please use the code below:
if (!is_admin() || (is_admin() && wp_doing_ajax())) {
return $content;
}, 50, 2);
(@mert2312)
@astghik hello, thank for your reply. that worked for admin part and resolved the error issues, but ajax part is still not working. maybe the function wp_doing_ajax() should be replaced with something else or modified somehow, but I don't know how to deal with this. still a huge help, thanks for that.
@mert2312,
We see everything is working fine now. Please explain using some screenshots the issue you see. I'd also suggest you press CTRL + F5 (twice) on the frontend before checking.
