Comment form not showing
(@pascalth)
Topic starter   [#3437]
Hey,
I set-up WPDiscuz and the comment form is showing on all my posts but one.
This is the post in question: coindiligent(DOT)com/how-to-invest-in-cryptocurrency
Do you know how I can fix this?
Topic Tags
Rina
 Rina
(@arina)
Support Team Registered
Hi @pascalth,
Please navigate to Dashboard > Comments > Forms admin page, edit the default form and make sure you don't disable the comment form for the current post ID.
More info here: https://wpdiscuz.com/docs/wpdiscuz-documentation/getting-started/custom-comment-form/comment-form-settings/#comment_form_for_post_id
Also, deactivate wpDiscuz and check if the default comment form shows or not?
