[Solved] Private messages not working
(@tomiradi)
[#4750]
On my website https://tomiradi.com/forum we have a problem with private messages - When I write a message and try to send the page refreshes but message just isn't sent.
This is a new issue as messages worked fine a week ago.
(@tomiradi)
I just realized any posting or replying on forum on my website doesn't work - when someone posts new messages simply don't appear in the thread. Could there be something wrong with database?
@tomiradi,
It seems there is a plugin conflict. Have you installed some other plugins recently? If yes, please deactivate those plugins one by one and check after each deactivation.
Don't forget to delete all caches and press CTRL+F5 on the frontend before checking.
(@tomiradi)
Hi, it turned out it was conflict with the plugin Hummingbird.
Thanks,
Marko
