[Solved] Integrate WPforo Rank with MyCred Rank?
(@labradorman)
[#3258]
I just notice that after integrating MyCred, we now have at least two types of ranking, (1) Wpforo original ranks (where we have 1stars to 10 stars, ranking based on ‘number of posts’), and (2) MyCred rank (where we set and design by ourselves)
My issue is I want only one ranking system based on ‘nunber of posts’ and ‘vote up’. So I tried to think of some options which need your advice which ones are possible :
- Use only wpforo original star ranking, but somehow integrate with MyCred hook on vote-up
- Disable Wpforo’s original ranking, and use only MyCred Ranking
- Other options, please advise.
Best Regards,
Labradorman
PS: extra question: is there anyways to use a small image instead of favicon in wpforo’s original ranking ?
There is no way to change the ranking logic of the default Rank System, so it's better to configure the MyCRED one. There are more options for that in MyCRED system.
(@labradorman)
Thanks. In that case can we disable the default ranking system?
(@labradorman)
OK just found the option to disable the default ranking system.
