Feature Requests: Daily Limits on Points and Others
 juda
(@juda)
[#3467]
More suggestions. Would be glad if you can consider.
Request 1:
option to put daily limits to how many times a user can earn points for a specific action (see default mycred hooks for how they implement theirs). For example limit users to only be able to earn points from voting 10 times a day. any other vote will not earn points after the daily limit is exceeded. similar limits for likes, comments, posts and wherever such limits make sense
These other requests are not really exactly for the mycred addon, just requests for the Q n A
Request 2:
option to allow correct answer or answer with the highest vote to appear at the top of answers to a question. if more than one answer is marked then sort them according to number of votes. Sort the whole list based on the number of votes with highest votes at the top (like stackoverflow)
Request 3:
disable voting on the question, only vote on the answers
(@devin)
Is there an option to limit points / day in the mycred wpforo integration? I would really like this option as well.
Thanks,
Devin
@juda, @devin,
Request 1:
We will take it into consideration and if it’s possible, we will add it in the near future.
Request 2:
Request 3:
We’re going to discuss with our team and if it’s possible we’ll add it, in any case, we’ll keep you informed.
Posted by: @elvina
Request 2:
This is work in this way since wpForo 1.6.0 version. The Answers sorting options, by default is set "most voted".
Please follow the topic provided above to get more info: https://wpforo.com/community/wpforo-announcements/wpforo-1-6-0-is-released/
Request 3:
Please navigate to the Dashboard > Forums > Settings > Styles admin page, put the following CSS code in the "Custom CSS code" textarea:
.wpfp-first .wpforo-post .wpf-left .wpforo-post-voting{
display: none;
Don't forget to delete all caches and pressCTRL+F5(twice) on the frontend before checking.
@juda,@devin,
Request 1:
We’ve added a new feature in the add-on.
Please update the add-on to the latest version v. 1.1.1.
(@devin)
@elvina Thanks!! I appreciate the fast turnaround on this! The users on my website have really been enjoying wpForo...after getting it up and running, I'd definitely choose wpForo over bbPress. Much cleaner and more modern. Thanks again! - Devin
(@devin)
@elvina One quick quick question... on the attached screenshot, just to confirm, this means they will get 7 points for adding a topic and the daily limit is 35 points total?
Screen Shot 2020 04 16 at 9.06.05 AM
@devin,
yes. In case if you change the daily limit value, the total value of points will be changed as well.
