Can't get posts to sync manually or automatically
(@treybiker)
[#13939]
* In case this has something to do with the below issue...
I recently had an issue with this particular forum disappearing when I was adding another forum and didn't realize it defaulted it as the parent forum and after I saved it without noticing, it deleted my entire forum & subforums. It took you all a bit to get back so I went and re-created all of the forums & subforums because I would have lost too much work using my previous backup...
Something odd is going on. Cross posting worked fine before but now, when I create or update a post, the Blog to Forum Cross Posting dropdown menu is there along with the listed forum I want to cross post to, but it won't cross post it when I save it. I have tried doing it manually & automatically with new and existing posts and even syncing old posts with the proper category chosen.
Worth noting, when I try to turn cross-posting off on the post itself and save it, cross-posting is still turned on when I close the page and come back to edit the post. I have cleared all caches in wpForo, the forums, wpDiscuz, Wordpress, and refreshed my permalinks. I've tried deactivating/activating all of them  turning on & off Wordpress shortcode option.
Any ideas???
- Trey
Hi, Trey.
We'll check and get back to you soon.
We don't find such an issue on our test websites. Could you please send the admin login details to info[at]gvectors.com email address? I'll ask the developers to check the issue for you.
