[Solved] I can't attach images to my forum
 dydy
(@dydy)
[#6364]
i purchased wpforo advanced attachment and other related addon but i cant attached images to my forum.
My exempted my forum page fro caching but to be double sure i created a dummy sub-domain and disabled the caching plugin and it still doesn't change the situation.
The domain is https://www.decentenews.com/forum
Hi @dydy,
Please register some new testing user and send the user's login details to info[at]gvectors.com email address. Please make sure the user has permission to attach files.
 dydy
(@dydy)
Hi @astghik,
I have done as required, there is an additional details with admin privilleges.
Thanks.
ok @dydy, thank you.
We'll check and back to you asap.
Hi @dydy,
the issue comes from the "Asset CleanUp: Page Speed Booster" plugin.
We've deactivated the plugin and it's working fine. Press CTRL+F5 (twice) on the frontend and check it.
The plugin doesn't allow loading js libraries, thus it doesn't allow the plugin to work properly.
You should either keep this plugin deactivated or contact the plugin support and ask them to fix the issue.
 dydy
(@dydy)
Hi @astghik,
Thank you for your kind and quick response.
i have deactivated the plugin and observed i can now upload images but the images are broken. i have attached a screenshot.
I tried it out on the site and the subdomain and got the same result.
Thanks.
Screenshot (392)
Hi @dydy,
Please navigate to Dashboard > Forums > Settings > Addons > Attachments admin page, disable the "Secure Attachment URLs" option, delete all caches and check again.
 dydy
(@dydy)
@astghik Thanks
It now works fine
