[Solved] Attachment works for admin not for user
(@scoreclub007)
[#4140]
I can use the attachment load images as admin without a problem.
When using as a member/user I get the following when I open the attachment window.
It gives me the top image and menus of my site and it is non-functional.
Capture Messaging issue
Once I close the window I get this weird double and quadrupled menu on my screen.
Capture Messaging issue 02
And at that point I am logged out.
Don't know where to look for that.
Thank you,
Alain
Hi @scoreclub007,
Please register some new user and send the user's login details with your forum URL to info[at]gvectors.come mail address to allow us to check it.
(@scoreclub007)
Ok, I have created this and emailing right now.
Hi @scoreclub007,
This kind of issue is usually caused by either conflict with other plugins or the active theme.
Please deactivate the plugins one by one and check after each deactivation to find the problem maker one.
js error
(@scoreclub007)
Hi, got it solved.
It wasn't a plugin exactly - I deactivated most of them and then I tried turning off the maintenance mode... and that's what it was: the maintenance mode.
So there you go! Thank you.
Alain
Thank you for letting us know. Glad to hear that the issue is solved.
