Paid Addons Support Forum Only
Please note, that here we only support Paid Addons issues and questions.
gVectors Support staff works from 6am to 6pm (GMT+0)
All questions related to wpForo and wpDiscuz free plugins should be asked in the corresponding plugin support forum:
wpDiscuz Support Forum   wpForo Support Forum
Data are not inserted in reporting comments
Communications Wikimedia Foundation
(@communications-wikimedia-foundation)
I'm having an issue with the comment report & flagging add-on. When flagging a comment the form comes up and you can select an option. When you click "Send" it reports back "Data are not inserted".
This does not matter if the user is logged in or a guest.
Screen Shot 2020 07 14 at 8.20.41 PM
Here is the settings in the plugin itself. I have the most recent version. I have deactivated, uninstalled, and reinstalled.
Screen Shot 2020 07 14 at 8.31.32 PM
You can see this for yourself on this blog post. Try and flag the test comment.
https://diff.wikimedia.org/2020/07/14/welcome-to-diff-a-community-blog-for-the-wikimedia-movement/
I don't see any errors in the console and the message is rather vague. Could you please help troubleshoot?
(@astghik)
Support Team
Hi @communications-wikimedia-foundation,
There is not such an issue on our test websites. This is something specific in your case. Could you please send the admin login details to info[at]gvectors.comn email address? I'll ask the developers to check the issue for you.
An email has been sent.
(@astghik)
Support Team
We're just a regular user so can't check the issue. Please change the role of the user to Admin and let us know.
Please try again. You may be requested to setup a two-factor authentication method in your profile before being able to edit the site.
Moderator
Noble Member
We can not access your website via the access provided by you. So please one more time send the admin login detail to info[at]gvectors.com email address.
Also please leave the email subject here to allow us to easily find it.
@elvina I have resent the login details with more specific instructions. The email subject line is: "RE: Data are not inserted in reporting comments".
Moderator
Noble Member
Please enable plugin editing because developers cannot add / edit / deactivate and activate the plugin and let us know.
