Help with Login URL
Help with Login URL
(@guillermorivr)
Topic starter   [#5863]
Hello, I am using the WPDiscuz plugin.
I want to modify the URL of “Please LOGIN to comment”.
I have added this code in the functions.php file of my WordPress theme (Magnitude) but it doesn’t work, I am always redirected to wp-login.php.
add_filter (‘login_url’, ‘my_login_linkchanger’);
function my_login_linkchanger ($ link) {
/ * what to do with the link * /
   return home_url (‘/ login’);
I need your help because it is very important to change the URL for me.
Thanks and regards.
Hi @guillermorivr,
First you should have a login page. Do you have  a login page other than the default WordPress wp-login.php? If you don't have any other login page then you don't have any URL to change.
In case if you have one, and the URL of that page is example.com/my-login-page/ , the inserted code should look like this:
add_filter ('login_url', 'my_login_linkchanger');
function my_login_linkchanger ($link) {
      return home_url ('/my-login-page/');
(@guillermorivr)
I have inserted the code at the end of the functions.php file (I see this file appears in wp-includes and in my theme directory). I modify the file that is inside the directory of my theme.
After doing this, now when I go to view the content of an article, an error appears.
Have I misplaced the code or what is happening?
Attached images.
p2
code
@guillermorivr,
I updated the code, please change it. The wrong part was copied from your post. So that too.
(@guillermorivr)
@tomson
Well now, thanks! One last question, how can I be redirected to the article after login?
@guillermorivr,
Please remove the code provided above and use the following one and you'll be redirected to the same post page.
global $post;
$redirect_to = '';
if (!empty($post->ID)) {
$redirect_to = '?redirect_to=' . get_permalink($post->ID);
return home_url ('/my-login-page/' . $redirect_to);
Save, delete all caches, and check again.
